How to sync two songs from different sources (Djay Pro + iPad apps)
Hi!
I have the Denon MC6000 controller and it’s fantastic using Djay Pro for Mac. t want to export the song from my iPad app and then loaded into a deck because I create them on the go. E.g. Using LaunchPad (https://itunes.apple.com/gb/app/novat…)
Do you know a way how can I achieve this special sync with the same results as traditional sync?
There’s no automatic Sync between djay Pro and djay 2. You’d have to manually sync them.
Why not exporting your songs onto your computer? You could add them to your iTunes library and directly play them in djay Pro.
