I have ideas for DJAY Pro iPad and Mac version
for auto play, add volume sensor. when the tracks starts to fade in
volume, transition over to next track. there are certain tracks that are
quiet at the end and it transitions sounds bad. down and try the program
for mac called MegaSeg. that it is a professional radio station program
and the segue are excellent http://www.megaseg.com/download -
offer an in app purchase for a FULL Equalizer. Mobile DJs can carry
less if built into the software. would give the DJ better control over the
sound than just a 3 band. I would gladly pay $5.99 for that option.
*There is still a bug with iDJPro where there is distortion in audioo
output if you plug controller in first then start program. If you start
program then plug controller in, it is fine. last night had to switch to
aux while I unplugged iPad pro beginning of night *
