You can only load one iTunes library at a time. Switch the library in iTunes:
- quit iTunes
- alt-click on iTunes
- select “Choose Library”
- load your other library
then select “Refresh Library” in djay’s “Library” menu.
i’m using a Macbook
i’m using a Macbook
