I have been adding tracks on to my iCloud Drive and accessing them with djay pro on my iPad.
The ‘my files’ list only seems to hold 10 songs so I have to reload tracks constantly. This on its own isn’t a massive issue but when I reload the track settings have been forgotten so I have to reset cue points etc.
Any ideas - surely the list can hold more than 10 tracks?!
we wrote a utility to convert cue points set in another application to djay. As a bonus the documentation explains how you can backup and restore your complete djay settings folder making it easier to use it on multiple iOS devices without re-analyzing or setting your cue points again.
So if I eject and reload the cues stay - as they should and work fine.
The problem arises when I have to load the track back into the ‘my list’ folder. As far as I can see this folder can only hold 10 tracks meaning that when you import a new track one drops off the bottom of the list.
It is at this point that I get the issue. If there is a good wifi connection then we’re ok but if I’m offline a track that has been previously loaded into the ‘my list’ folder can be loaded (from iCloud Drive) and it has all the info, bpm etc, but not the cue points.
I assume that the cue info is held in the cloud but even though I can’t see the tracks in the list the track has actually been stored on my iPad?!
