iCloud synchronization does not work
The synchronization via iCloud between iPad and iPhone does not work for me. iCloud is enabled on both devices and so is the synchronization in DJay Pro. But on the iPhone the status is constantly on “initialization”. Does anyone know the problem and a solution for it?
Hi @Chris_R,
Thanks for posting your question!
Could you please attach a screenshot of the “Initialization” screen that you are seeing so we can better assist you?
Looking forward to your response!
Sure, here the screenshot:
Hi @Chris_R,
Thanks for the screenshot!
If you restart your device or the app is there a change in the iCloud status?
Have you tried turning off iCloud in the settings app and re-enabling it to see if that solves the issue?
I tried rebooting, but that didn’t change anything. The state is still unchanged, by the way, also on the Mac. iCloud itself works otherwise.
Hi @Chris_R,
This may be related to an issue with your djay library in which we’ll need to take a closer look at the situation with you.
Could you please send an email to us via our support request form found at the link below regarding this iCloud sync issue?
https://help.algoriddim.com/hc/en-us/requests/new
Please be sure to include a link to this thread in your email so we can better keep track of this issue.
Looking forward to hearing from you!
