Hello. i have idjay 2 for ipad being used on the idj pro. for some reason i can not see the fade bar on the bottom of the two turn tables anymore. only the FX modes show up covering that area under the turn tables. any thoughts on fixing that?
Hi Carol,
The UI for the iDJ Pro is specially designed and optimized. With this in mind, the UI doesn’t show any redundant controls that are already available on the iDJ Pro controller itself.
