this app works ok, but when you place your ipad in the slot into the mixer , the direction is not following, therfore it’s in sideway, jog wheel scratches, but only for a few seconds, then it comes back in ,Do I need another ipad ,cause the ipad 1 not working properly, the light don’t light up on the top until pressed, so if your gig is in the dark youe SOL
Hi Alvin,
Which djay version are you using? Please tap the gear icon and scroll down to determine the exact version number.
Also, please open the iPad Settings and go to General > About. Is there an entry saying “IDJ PRO”? Try using the iDJ Pro with djay and when the issue occurs, check back here to see if the entry is still there.
