Algoriddim employees are here to help…thats what im reading up the corner, so please revert the previous version for now, so we can use the program, and try to fix the problem in the newer version!
It would also be cool if we could self-arrange FX buttons on wego for different effects! is that possible to integrate in new version?? Now the effects are set to default…echo, flanger and some sound cutter effect, it would be great if we can choose and map them !!
Could they not just put the previous version on iTunes until they sort this out, I am paying for Spotify I bought pioneer we go and now are useless until The waveform stuttering beat arch glitches are sorted, The previous version worked fine
Before was good, now is bad. I can’t see the problem to return old version. And all this trouble before Christmas party’s!!! I’m happy that I also have Traktor DJ! This program works perfectly …
