Purchased a song on Beatport… Imported to iTunes… the song does not show as available to mix in Djay Pro (iPad) under iTunes… ??
Anybody know what’s up? Does it have to have been purchased from iTunes or something?
Thanks.
Thanks.
Hi ThereOnlyls,
have you synchronised your iPad to your iTunes (Mac)?
Every purchased song which is playing fine in iTunes should work with djay Pro for the iPad.
Cheers,Lukas E.
