when I’m using the deck in auto mix sometimes it goes crazy with the pitch not know if someone else has had this problem
could you check if “Auto Sync BPM” is activated in the djay Pro preferences?
No iTunes is not interfering with djay. Could you send us a mail with an exemplary video of the pitch behaviour to support@algoriddim.com.
Our apologies.
not, I checked and it’s not. I have a few days testing and he has not. Itunes is possible that if this work interferes with DJ Pro?
