Hi guys, would it be possible to slightly increase the size of the lyrics and perhaps even the space between songs? I’ve already set everything to maximum, but it’s still small, and it could be a limitation or even a visual nuisance. I’ve attached an example of a size in Traktor, which isn’t even the largest, but it’s a great compromise in terms of visualization. As you can see in the photo, the lyrics and space are larger than in DJ Pro.
Thanks for the suggestion @Screma. I’ll share this with our devs for consideration.
I was just wondering if it’s possible to increase the font size in the library. Even at the biggest font size is old folks have a hard time seeing the library. Would be easier to work with a bigger font. Thanks
On MacOS I use the keyboard shortcut -space bar- to toggle the library into full screen mode. Does that help you at all?
Hi @Manriquezjose, thanks for the suggestion. I’ve merged it with this existing one. Please revote above.
