Device model (e.g. 2020 iPad Air 4th Gen):
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Is there going to be built integration with the six built in FX buttons for the Hercules T10? Right now it seems I can only midi map the two FX knobs on the T10.
Hi @ianz1, welcome to the Community! Thanks for flagging this. You’re right that the six FX buttons on the T10 aren’t doing anything with the built-in mapping right now. I’d like to get this to our QA team, and a few details would really help:
Your device model, OS version number and djay version number.
Your T10 firmware version.
When you press each of the six FX buttons, does anything change on screen? Do the buttons light up?
Do the FX paddles do anything?
Open the T10’s MIDI Configuration window (on iPad/iPhone: Dashboard > Settings > MIDI devices) and press each FX button. Does a new entry appear in the list, or does nothing happen?
Have you edited or replaced the built-in T10 mapping?
A short video of you pressing the buttons with djay on screen would be perfect if you can manage it. Thanks!
Not sure if your team made a change earlier today, but it started working. The one thing I noticed though is that FX buttons 1-3 only works for Deck 1 and 3-6 works only for Deck 2. In Serato the six buttons works for either deck. Is this something that is going to be improved?
Also the crossfader bleeds into each side if you set the curve all the way to minium. It does not do that in Serato also.
I am using version MacBook Air, Golden Gate, 5.6.10
Hi @ianz1, thanks for the update, and glad to hear the FX buttons are working for you!
What you’re seeing matches how the T10 is laid out by Hercules: buttons 1–3 control Deck 1 and buttons 4–6 control Deck 2. Being able to use all six buttons on either deck is a great idea, and I’ve passed it on to the team as a feature request.
Two quick questions:
Did anything change on your side before they started working? For example, reconnecting the T10, restarting djay, or editing the MIDI mapping. Nothing changed in djay on our side today, so I’d like to understand what made the difference.
When you press one of the FX buttons, what happens in djay? Does it select a different effect, or turn an effect on? And do you need the paddle as well?
Regarding your Crossfader question, please create a new topic for this so we can keep each issue/discussion organize. In your new topic, please share your complete setup details along with a short video of the issue including your crossfader settings and audio devices settings. Thanks!
