Hi @BrianR, thanks for the video. I went through it frame by frame and there’s a pattern. A couple of times, changing the Four Decks options (the waveform position, or switching to the grid layout) made the djay window resize itself so it got narrower and ran off the bottom of your screen. Once the window got stretched back out to fill the display, the whole deck area ended up sitting a little too high, tucked under the toolbar.
It also looks like there’s a quick fix in your recording. Around the 43 second mark you dragged the window down and snapped it back to the top of the screen, and after that everything lined up properly again. Next time it happens, can you try that and let me know if it clears it up every time?
One other thing would really help me narrow it down: does it still happen if you run djay in proper full screen (the green button at the top left of the window) instead of a window stretched to fill the screen?
Thanks for confirming @BrianR. I will pass this onto our engineering team for further review. In the meantime, I recommend that you run djay in full screen mode instead. Thanks!
