INTERVAL 12: Key matching for djay + Ableton hybrid sets
Hey everyone! I’m Pepper, a DJ and musician building tools independently under UNIT & SIGNAL.
I built INTERVAL 12 for hybrid DJ sets, combining tracks in djay Pro with your own audio and MIDI layers in Ableton Live.
The idea is simple: build a channel of vocal clips, synth loops or pads, and bring them into your DJ set without having to organize everything into matching keys beforehand. Once you set the source key and transposition baseline correctly, INTERVAL 12 adjusts those layers to follow your selected djay deck, automatically or manually.
Your material doesn’t need to start in the same key as the track you’re mixing. It handles key/transposition, not tempo sync or automatic key detection.
Demo and details:
Requires an Apple Silicon Mac, macOS 13+, djay Pro and Ableton Live with Max for Live.
This is my own independent project, not an official Algoriddim product. I’d love to hear from other hybrid DJs.
how are you bringing loops and instruments into your sets?
Very interesting! Thanks for sharing @Peppertheband
:heart_eyes: !!!
the idea behind ableton following the key of djpro makes sense…
adjusting of pitch by semitone’s is great & all… but as the pitch of the ableton samples moves further from its original source, adjusting the “cents” just for fine tuning will always be helpful
as far as a hybrid setup goes… i went the way of dual maschine Jam’s + traktor z1 mk1 interface,
i have way more flexibility with managing audio/midi controls of DJpro/Maschine/Reaper/ipad/VST3’'s with only a pair Mjams
everything audio is routed into Reaper or runs as a VST3i, essentially making Reaper the main hub
so i have 2 VST’s (mixedinkey & hornet_songkey) which can monitor any given RT audio track and output the Key, …but adjusting pitch is a manual process using the kiloheartz pitch shift VST3
the latest addition to my VST3’s is a *.sid file player(c64 sid player) which sync’s up to the host DAW and has separate volume controls, beat jump & loop controls, quite the neat little vst3
Man, that’s a pretty wild setup . I like how everyone finds their own way to make all these different tools work together.
And you’re absolutely right about fine-tuning the cents! That’s actually a really interesting point, especially when you’re moving further away from the original key.
My whole idea with INTERVAL 12 was to make the process as seamless as possible. I’ve spent so many years fighting with different software and MIDI routing that I just wanted something that would let me focus on playing music instead of constantly adjusting things. :joy:
I really like your approach with Reaper as the main hub though! And two Maschine Jams is a pretty cool way to control everything. Would love to see that setup in action sometime!
one of the issues with many pitch plugins, is they tend to introduce added Latency(PDC),
Reaper has what they call a JS-plugin which can handle semitones/octaves, it also has cents which you can increase in small increments which helps with fine tuning, the good thing is the cents increments is barely noticeable when gradually moving it incrementally or in the opposite direction
this can really help in making the Djay tracks sound in key when its slightly out…
its something i will implement in my growing Reaper template
