Just purchased ion Discover DJ. I am running OS X 10.6 (Mac). What is the configuration setting to get jog wheel work properly
Hi Ping,
Which djay version do you have? Ion Discover DJ is natively supported so you shouldn’t have to configure anything. Please click on “MIDI” on the menu bar, select “Configure…” and make sure that “Built-in” mapping is selected.
Warren,
I am running version 3.0.1
