I’m really satisfied with the ION controller interface, but there’s a way to disable the jog wheel to work while music is playing? The problem is the jog wheel is so sensible and you can bump your finger unmeant.
Thank you!
Thank you!
thank you for your feedback.
It would be great if this thread gets user attention which feel the same way.
Remapping a midi mapping file should always meet a big amount of users which feel that way too.
