iOS MIDI mapping
Hello
I’d like to buy a refurbished 9th generation iPad and I’d like to know if the iOS version of Djay Pro has MIDI mapping functionality. Currently, I’m using Serato DJ and I own a Pioneer DJM-S7 and two Pioneer PLX-CRSS12s, and I’d like some information on Djay Pro to see if it would be suitable for my needs.
A 9th gen iPad should work for DVS, but it won’t be able to run Neural Mix FX at 100%.
MIDI Mapping
  1. djay Pro supports MIDI mapping.
  2. DJM-S7 is officially supported in macOS/iOS and includes a built-in MIDI map for the S7.
  3. PLX-CRSS12s, should show up in djay Pro for mapping, as long as the MIDI implementation is standard.
Thanks @Michael_Wisniewski!
Agree, I have the iPad 9th Gen as a back up and although it does work, I find it to be a bit glitchy when using Neural effects..
Save a few more pennies and get a later version iPad.
I have the iPad Air 5th Gen and it works seamlessly
Hello
Thank you for all this information, I understand things a bit better now.
Sound advice this is.
