iPad lose communication with Rane one mk2
  • Device model :iPad Pro (11-inch) (4th generation)
  • Version of operating system (e.g. macOS 18.6.2:
  • Version of djay (e.g. 5.6.2
  • Hardware/controllers used Rane one mk2):
  • Hardware firmware version
During my gig last night the iPad temporarily lost connection with the rane several times I had to restart to make it stop. I was not touching anything at the time of the disconnect
Du
Hi @Five-0, this sounds like a USB cable, USB socket or interference issue. First, make sure you are using a high quality, properly shielded cable with dual ferrites. If you are, then I would try a different USB cable and check the USB sockets on the RANE One and your iPad for any debris or looseness. I would also try connecting to the other USB socket on the back of the RANE One.
Ok I’ll try that
Sounds good. Please let me know how it works out.
No issues with new usb cable….
I had a feeling… glad that solved it for you.
