Does anyone know if the wego3 works with the iPad Pro 9"? It’s not on the Pioneer website and I don’t want to make the investment in the iPad Pro if it won’t work together. I’ll just get an old Macbook. The iPad mini 4 lags a little with djay pro. That’s why I’m looking at the iPad pro.
Hi Willie,
all iPads no matter if Pro or Mini are supported as long as they are able to install djay, which the iPad Pro definitely is. So you can work with djay and the WeGo 3 via plug and play.
Have fun mixing.
