Does the DDJ-WeGo 3 work with the newest version of djay? I’ve tried to connect with my Android smartphone and nothing happens when I plug in.
Hi Michael,
The WeGo 3 is natively supported by Android, iOS, Mac and Windows
Please check if your connection on Android is working, which exact cable are you using?
