Is FLX4 supported on Windows?
Your question:
Hi everyone,
I’m thinking about getting the AlphaTheta DDJ-FLX4 and I’d like to know if it’s compatible with Djay Pro on Windows PC.
I’ve seen that it works well with Rekordbox and Serato, but I can’t find clear information about Djay Pro support — especially on Windows (not macOS).
Has anyone tried this setup? Does it work properly (plug-and-play, mapping, audio output, etc.)?
Thanks in advance for your help! :folded_hands:
Hi @Loic_Genin, yes this hardware is officially supported on Windows. For a full list of supported hardware please refer to the link below. Thanks!
