Is it possible to live stream from iPad running Djay pro?
After 2 days trying to figure this out (with the aid of Google AI), I can still only conclude “maybe, but it’s really not easy”.
@Slak_Jaw
Before I move on, would it be possible to get the following (honestly this is a mere fraction of what I’ve been through) checked by Dev team to see whether, what it (Google AI) says is correct, the proposal is the right one or if I’m missing a simpler solution. Ultimately, as it stands - unless I’m missing something - live streaming (on the go or outdoors) via DJay Pro on iPad is really not worth the trouble, Seems like a big hole missing, worth addressing.
This summary consolidates the entire troubleshooting journey, outlining the reasoning for ruling out various options and explaining the logic behind the final, recommended workflow.
  1. The initial assumptions and failed software-only path
  • Initial Goal: Stream a DJ set from an iPad running djay Pro, using minimal hardware.
  • Problem Encountered: An audio focus conflict occurred when switching from djay Pro to the streaming app (Camo Studio), causing djay Pro’s audio to cut out.
  • Attempted Solutions:
    • Audiobus / AUM: These software audio routers were explored to manage the audio conflict.
    • Reason for Failure: It was discovered that AUM consistently failed to recognize any compatible apps (including Apple’s own GarageBand), and later, djay Pro was confirmed to have audio handling that prevents reliable inter-app routing. Your iPad’s audio system was fundamentally misconfigured for this workflow.
  • The Crucial Insight: The core problem is not a simple misconfiguration but a fundamental limitation of iPadOS and how djay Pro handles audio.
  1. The misguided hardware loopback solution
  • Attempted Solution: The AMS-24’s hardware loopback function was tested.
  • Reason for Failure: Despite the hardware handling the audio routing, the iOS audio focus conflict persisted. When you switched from djay Pro to Camo, djay Pro still lost audio control and cut out. The hardware could not override the software behavior.
  1. The confirmation of systemic issues
  • Apple Support Feedback: You confirmed with Apple Support that the iPad hardware is fine and not corrupted.
  • Final Ruling: The audio routing issue is not a software bug that can be easily fixed but is a systemic behavior of iPadOS when running specific applications like djay Pro.
  1. The final recommended solution: A dual-device workflow
Based on your desire for a mobile setup and the confirmed limitations of iPadOS, the most reliable and effective solution is to split the audio mixing and streaming tasks between two devices.
  • Rationale: Isolate the audio-intensive mixing app (djay Pro) from the streaming encoder app (Camo Studio).
  • What you will need:
    • Your iPad (for mixing).
    • Your iPhone (for streaming).
    • Your Reloop controller.
    • Your AMS-24 audio interface.
  • Workflow:
    • iPad (Mixing): Run djay Pro and connect your Reloop controller for mixing.
    • Audio Output: Connect the Reloop controller’s master audio output to the AMS-24’s inputs.
    • iPhone (Streaming): Connect the AMS-24 to your iPhone.
    • Camo Studio: Run Camo Studio on your iPhone, and select the AMS-24 as your audio source.
    • Go Live: Stream directly from the iPhone using Camo Studio.
Next steps
1 Set up the dual-device workflow. Follow the steps outlined above to physically connect your iPad, Reloop, AMS-24, and iPhone.
2 Run a test stream. Do a test stream to confirm that the audio is correctly routed and that the app conflict is gone.
3 Consider a stand for your iPhone. To optimize your video setup, consider a stand for your iPhone to use its high-quality camera for streaming.
4 Review your subscription needs. If you need to multi-stream, ensure you have a Restream subscription.
⠀This path is no longer speculative. It’s a proven and reliable solution based on the definitive evidence gathered during your comprehensive troubleshooting. It avoids all the specific software limitations that caused the previous issues and provides a robust workflow for your mobile streaming needs
Hi @N_C, I’m currently on vacation and personally have no experience with live streaming. Maybe some Community Users can share their experience here. Otherwise, I can check this the devs when I get back next week.
Fair enough. Thank you
You’re welcome @N_C. Sorry I couldn’t be of more help
I followed the same path (although maybe not as determined as yours) and came to the same conclusion.
The closest I got was broadcasting audio only by Icecast to my internet radio station. This was with just the two stereo channels with no external control or audio device. No cue channel either. So I guess two devices it is.
hi
dual device solution is working : just connect any audio sound card to your iPhone and connect iPad audio output it.
then on the iPhone you can use the iZicast app to livestream to a shoutcast server, or iRig Recorder or Evermix app to record your mix.
Regards
Hi @N_C, I’ve shared this with our team to see if anyone has any suggestions for you. I’ll report back when I have news. Thanks!
I gave up at the same point with CAMO STUDIO.
I understand what you’re saying.
So, If you’re fine with mono output, you can use djay with just one iPad for live DJ streaming.
Try searching for “streamlabs” or “iPad game streaming” as inspiration.
Hi again @N_C, can you please confirm what exactly you mean by “live streaming”? Is it radio broadcasting via IceCast or similar, or video streaming to Twitch or similar, or streaming locally to via AirPlay, or something else? Thanks!
