Hi Andy Cadman,
thank you for your post.
Could you tell us to which djay Pro version you are referring?
Thank you in advance.
As the SB2 is a 2 deck controller we recommend using it in the natively supported 2 deck mode.
If you still want to control 4 decks you would have to change the midi mapping of the controller or connect another midi device.
Maybe some other users have experience with this and can share their ideas.
Hi, version 1.3.1
