Is there any way to stop djay from reducing the microphone input level to zero each time it is switched on with SHIFT M?
This is currently not possible. This behavior was initially intended to prevent sudden feedbacks. I’ll pass this on as a request to our developers. We’ll be sure to review the correct behavior for the mic volume setting.
I have to agree that this is an annoyance! You either need to find a way to keep the volume level the same when the mic is switched on/off, or add a mute button so you can mute the microphone while a song/track is playing. I had to record a two-hour show the other day keeping the mike “live” the entire time so I wouldn’t have to fiddle with the volume control every time I turned it on/off.
