For the last week or more, I have a problem with DJ Pro on Mac when playing from Spotify. The loading time is very long and tracks just stop or brake playing in the middle.
There is no problem with my internet as its fast and stable.
Hey there,
thank you for your post and we are sorry to hear that. Is this happening with every song you want to play?
Did you experience the same behaviour in the Spotify application?
Cheers,Lukas E.
Hi Lukas,
Many thanks for your response.
Best,
Piotr
djay Pro Version 1.0.26412.0
Windows 10 Pro 64 bit version 1607
When using automix on a Spotify playlist the software hangs about 10-15 songs in. The deck that was playing will show the turntable RPM dimples as spinning, but the album cover will stay in one position. The deck getting ready to start up to get ready, but it will stop and the univarsal wait symbols will keep spinning. This never happened on the beta version. I did a 5 hour automix session with no crashes or hang ups on the beta version.
Not sure why the official release would have this problem.
