Jog Wheel Displays on Pioneer FLX 10
So @Slak_Jaw So this is not unlocked yet by AlphaTheta? In my head I think it was because of it working with the Macbook. So you would like us to push to AlphaTheta?
Hi @DJNizz, that is correct. It needs to be enabled by AlphaTheta specifically for iOS, likely via a firmware update, before it can be implemented on our end. It helps if users like yourself push the issue directly with them. We are pushing from our end as well, but it helps for them to be aware of user demand directly. Thanks.
Sent mail to their support now on this topic.. :+1:
Great! Thanks @DJNizz
in order to make it easy for everyone,
Click the link
https://forums.pioneerdj.com/hc/en-us/requests/new?ticket_form_id=202826
Choose the Flx10 from the drop down manu
copy and paste:
Dear AlphaTheta Product Team,
I am a DDJ-FLX10 owner and would like to submit a feature request regarding support for Algoriddim DJAY on iOS (iPad and iPhone).
I have been using DJAY with my DDJ-FLX10, and overall the experience is excellent. The controller works very well with DJAY, and the only significant feature currently missing is support for the jog wheel displays.
I contacted Algoriddim support regarding this issue, and they advised that support for the jog wheel displays requires cooperation from AlphaTheta and access to the necessary protocol or SDK information before they can implement it.
As a customer, I would greatly appreciate AlphaTheta enabling or documenting access to the jog wheel display functionality for DJAY. The FLX10 is an outstanding controller, and full jog display support would make it an even better option for DJs who prefer DJAY on iPad and iPhone.
There is a growing community of DJs using iOS devices professionally, and improved integration between AlphaTheta hardware and DJAY would add significant value to the FLX10 platform.
Thank you for your consideration. I hope AlphaTheta and Algoriddim can work together to make this feature available.
Kind regards
Nice! Thanks for sharing @Fridmanator
Please disregard this thread - can’t be done due to lack of drivers / iOS restriction. This is a DEAD END
Answer from Alpha Theta support in less than one hour of logging the ticket suggested:
James,
I’m sorry, the issue is that the DDJ requires drivers to run the jog displays, and unfortunately iOS does not support the use of drivers, hence no display output to the jogs from iOS.
Thank you for your understanding,
Pulse
AlphaTheta Support Manager
Thanks for sharing @James_Gillies
