Key command to skip through tracks in playlist
Hi!
Djay has a cool feature where you can quickly jump to the top or bottom of the playlist or any list by using Option + up/down arrow keys.
It would be great if we can have a similar feature with key commands for jumping in increments of 20, 30, 50, ect.. or even have user defined increments.
This would be very useful for large playlist or the search result list, and all lists in the Side Bar.
Using the Playlist Filter and setting the BPM filter can help to skip around the playlists but it only works for the main playlist, all other list in the side bar or search result you have to scroll for days.
Thanks for the suggestion @Donn. I’ll share this with the devs for consideration.
