Key Notation Issue when Exporting to USB (OneLibrary)
When I export a playlist to a USB drive using Djay Pro, The song’s Key notation is alphanumeric within Djay Pro, But when that playlist from the same USB is loaded up in Rekordbox software (either on desktop or on my all-in-one controller) the Key notation of the songs show as Classical. I’ve made sure to set all software to alphanumeric, and made sure to analyze before exporting, but to no avail. This happens regardless of using third-party software such as Mixed In Key to overwrite the metadata too. Is there something I’m not doing correctly or is this an inherent issue using Djay Pro to export via OneLibrary?
  • MacBook Pro M2 Max (2023)
  • MacOS 26.5.2 (25F84)
  • Djay Pro 5.6.7
  • Pioneer FLX10 / Omnis-Duo
  • ver. 1.14: / 1.23
Hi @itsdjmikeyb, welcome to the Community! Thanks for the detailed setup info and screenshot. Can you please share screenshots of your djay Key notation settings and your Rekordbox Key notation settings?
Sure Can! (Only allows me to do 1 pic per post since I’m a new user)
Hi again @itsdjmikeyb, thanks for the additional info. We were able to reproduce this and are investigating further. I’ll share more news when I have it.
