I’ve been working on expanding the MIDI mappings for my X1s and…
Thought I’d post this quick video showing how I’ve got the touch-based Toggle Library Expanded working automatically, and reverts when you let go!
https://share.icloud.com/photos/0bd9oe0VIUua6orN7axIGyHxg
Cheers
James
Thanks for sharing this @James_Gillies
Unless I’m missing something, you demonstrated it, which is great, but didn’t explain how you mapped it? I’m assuming that the touch part is mapped to expand library view?
Hi @BillPayer, sorry didn’t mean to be cryptic there!
I’d just got it working and had previously written it off as normally when mapped directly in Djay Pro you’d have to touch the Browse knob twice to first expand and then collapse the Library view.
I’m using the same technique as I did for getting the LED displays to work, and I’m currently writing up a procedure to show how that works.
Once done, adding the extra config for the touch-based Library view with auto-collapse when you let go will take about 5 minutes.
I’ll post those steps here when I get done building out the main procedure for the LED displays.
I hope that helps.
Cheers
James
Perfect, sounds good James. Thanks.
