- Hardware firmware version (e.g. 1.0.1):
- Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
Hello,
How can i change the Language of Djay Pro. Now it is in spanish but my Language is normally Dutch or English. But not spanish. My windows is in Dutch not spanish.
Hi @Compupat, welcome to the Community! The language used by djay is controlled by the system language of your OS.
If your Windows system language is set to English or Dutch and djay is still in Spanish,
- I suggest that you backup your djay Media Library database and any custom MIDI mappings, then uninstall djay, reboot your device, make sure you log into your device with Administrator Privileges, navigate to the official Microsoft Store (English version), then download and reinstall the latest version of djay.
- You can find the files above in the following location: https://help.algoriddim.com/hc/en-us/articles/360014912131-Where-does-djay-Pro-store-cue-points-and-other-metadata
- Copy the files to a new location or external drive before uninstalling djay. After reinstallation, you can simply copy these files back to their original locations to maintain your Hot Cues, Saved Loops, My Collection Playlists, History and Queue.
I hope that helps!
