Last Update Crash
I have crash problem with the last update on my Windows 10. It loads and then crash without any error.
We’re aware of a possible crash on launch that affects some of our beta testers and have submitted a fixed update to Microsoft. It should become available within about a day.
Our apologies for the inconvenience and thank you for participating in our beta program.
Same It loads and then crash without error
It’s works again after the new update :slight_smile:
Same, Windows 10, x86, PLENTY of power, 4 seconds loading at splash screen then vanishes / crashes.
I have the same Problem
tôi cũng bị giống bạn. cập nhật lên djpro beta mới là không dùng được
