So I’ve updated one of my ipads to the latest version of Djay 2 and left another with the older pre problem version…
My set up is a Numark idj pro…
Besides the choice of album cover view or list view when searching for tracks in my library I can’t see any differences between the two versions…
All the apparent problems have been fixed though…
One thing I have noticed with the new version is the headphones output is considerably lower,I haven’t had a chance to hook the console up to my powered speakers but the headphone volume is at least 70% lower…
This has been tested with direct back to back comparison with the headphone volume at max,same headphones,eq settings exactly the same and gain exactly the same playing the same track…
I did the comparison test with various songs all with the same result…
