Is it possible to change the layout so that the waveform is bigger (let’s say 50% of the screen) and the explorer window showing the tracks is smaller (like the two deck advanced layout in Traktor) ?
Two decks but the explorer takes a lot of space in the screen. I’d like to minimize explorer and maximize waveform.
Hi djtwok,
unfortunately further adjustments to the layout are not supported. How many decks are you using?
Cheers,Lukas E.
Hi djtwok,
we noticed your request, but in general to change the layout we need a very big amount of users which feel the same.
