Lock the fx tab
When using the app on an iPad, if I choose FX, it defaults to ‘Pad’, I only use Manual, so can it be set to default to Manual
Great idea, same thinking here.
Yes!
And also: if the dry/wet knob would remember it’s last setting. Always on Max is no subtle beauty for sure.
Thanks, Cal
Hi @David_Bielby,
Thanks for the great suggestion!
I will make sure to pass this along to our dev team for further consideration.
Have a nice day!
Hi everyone,
I have received some feedback from our dev team regarding this thread that I wanted to share with the community!
djay remembers the tools (NM, EQ, etc) state if all visible decks (i.e. left/right deck in 2 deck mode) are set to the same tool / tab when exiting the app (going back to the home screen).
So long as you set djay to show the manual tab in the FX section within the tool window on both decks then everything should come back the same way on the next launch of djay.
Have a great day!
Brilliant, that worked. Thank you.
