Did you work out how to change it? If you like I can send you a “clean” version with pads 1-8 mapped to cue points 1-8. Let me know
Unfortunately there is no conditional logic available.
Yes you can access the leds next to the Pads.
Here is the midi map with all the notes you asked about … http://www.reloop.com/media/custom/up…
I’ll do the clean version you asked for in the next days … I’m trying to solve thr problems you mentions in your comments on djtechtools
Daniel can you give me some more info about this please … I cant reproduce the fault.
“Other odd rotary things in Manual loop. Even though it normally tops out at 32. Sometimes returning from other modes you can get 10X that value. The value that gets executed is often one fourth of the value selected.”
The other feedback you gave me i am working on solutions now.
The best solution for this would be any supported Pioneer DDJ controller.
What hot loops are they Stubmeister?
Or a Beatpad 2
