Hello, I’d like to know if there are any MIDI commands I can map on my controller to enable/disable “Crossfader FX” and “Tempo Mix”, and also to switch the crossfader curve to “Cut” mode or simply disable it.
My request is on Windows and/or IOS.
Screenshots from macOS …
MIDI Commands (set Target → Mixer)
Crossfader Curve (under Settings → Sound)
Hi, and thanks for your response. This commands exists on Windows and IOS?
Thanks for sharing these @Michael_Wisniewski.
Hi @Chirro_Peres, yes these same MIDI commands are available on Windows and iOS. Here’s a screenshot from Windows. Just make sure you set the Target>Mixer then the following Actions will be accessible.
