Loops Rane one Mk2
  • Device model PC WINDOWS 11
  • Version of djay 5.5.1
  • Hardware/controllers used RANE ONE MK2
    YOUR QUESTION:
    Hello everyone, I’m having a small issue regarding loops with my Rane One MK2 controller.
    Let me explain quickly: when I create a loop, as soon as the loop restarts at the beginning, there’s like a tiny acceleration of the music for a split millisecond. It’s audible, and it’s very unpleasant.
    I tried with other competing software and I don’t have this problem.
    Do you have any idea what the issue could be?
    Thanks in advance.
Hi @Dlp_77, can you please capture and share a short screen recording of this?
Hi I don’t have a Rane One but a Rane Performer and I have the same issue with loops which I don’t have in Djay Pro with my small controller (Pioneer CDJ-400), on the Performer the loops are inconsistent and I have to make smalls corrections (touching the playing deck) while with the Pioneer it stays “on time”. I’m afraid it may be something related to the moving platters which is not consistent, because I’m running same software with same files and the only difference is the motorised platters…On the other hand the Performer with Serato doesn’t seem to be affected or must have some kind of correction for this issue :man_shrugging:t2:
I have the same or similar issue with my Rane one MKII
Thank you for your answers, they reassure me! I tried with my iPhone using the beta version, and I don’t hear the issue with the loops. So it must be coming from the software.
Hi @Dlp_77, since this sounds repeatable, can you please capture and share a short video of the issue that I can pass onto our engineering team for review? Thanks!
