Recent DJay 2.0.2 update,
Lost samples, labels still there but empty, no sound.
I did notice the samples I created in iTunes/ipad/apps/djay2/ documents.
How can I retrieve them, they’re showing up in my
Sample preset menu.
I can’t forget to mention the awesome job your team is doing, can’t wait for more updates.
Hi Fred,
Does it help if you try to re-select the Samples?
Hey guys,
Yes, that did work.
Hopefully in future updates will resolve this.
Since creating several presets take time.
But all is good, thanks again
Hello, try to reselect the Samples
