LPD8 MK2 Action list is empty in djay Pro 5.6.8
Device model: MacBook Pro Intel
Version of operating system: macOS Sequoia
Version of djay: 5.6.8
Hardware/controllers used:
  • Pioneer DDJ-FLX4
  • Akai LPD8 MK2
Hardware firmware version:
Latest available
MY QUESTION:
Hello,
I’m trying to use my Akai LPD8 MK2 as an FX controller with djay Pro.
I found a strange problem.
  • The LPD8 is detected by macOS.
  • MIDIView receives Note On/Off and CC messages correctly.
  • Akai LPD8 Editor communicates correctly with the controller.
  • The DDJ-FLX4 mapping editor works normally.
However, when I open:
MIDI > Configure LPD8 MK2
and press a pad, the MIDI message is detected, but the Action list is completely empty.
If I configure the DDJ-FLX4, all actions appear normally.
Has anyone seen this before?
Does anyone have a working .djayMidiMapping file for the Akai LPD8 MK2?
My goal is to use the LPD8 as a dedicated FX controller for djay Pro.
Thank you.
Hi @Javier_Suarez, welcome to the Community! I’ve never seen this behaviour before. Can you please capture and share a short screen recording of the issue to help clarify what’s happening? Thanks!
