Device model (e.g. 2020 iPad Air 4th Gen): Ipad Pro M5
Version of operating system (e.g. macOS 14.4.1):
Version of djay (e.g. 5.1.2):
Hardware/controllers used (e.g. Reloop Mixon 8 Pro):
Please consider sharing a short video or screenshots to help clarify your question
YOUR QUESTION:
When using the Magic Keyboard with Caps Lock on, Djay Pro stops responding to the arrow keys used to load tracks onto the deck, and the space bar fails to trigger playback; everything only starts working again after I turn Caps Lock off. Has anyone else experienced this problem?
sounds like it’s sending a midi signal that switches the default keyboard shortcut in djay settings. While ON and acting up, toggle “Enable keyboard shortcut” on and off, or swap the setting from Open Format DJ to Default, and see if that resolves it
Hi @MarcosAraujo, on iPad, Caps Lock is a system-level language switch by default, which may be what’s intercepting the key input. Try turning it off in iPadOS: Settings > General > Keyboard > Hardware Keyboard > Switch Languages using Caps Lock (off). If that switch isn’t there, go to Settings > General > Keyboard > Keyboards and remove any extra language keyboards so only your main one remains.
Could you also fill in your iPadOS version and djay version? That’ll help narrow it down if the above doesn’t do it. Thanks!
