Is there a way on iOSto manually adjust loops without them snapping to the grid?
Hi @ahsan,
Thanks for getting in touch and welcome to our new community!
You can set non-quantised loops in the manual loops tools section. Make sure the track is not playing and use the IN and OUT loop options in order to avoid snapping to the grid.
I hope this was helpful for you
Hi, thanks for the reply. It’s a little inconvenient though. During the set I would have to pause the music to manually adjust the loop.
