Guys, i need help. I want to mapping between Korg Nanopad 2 and Djay Pro in Windows system. How can i do this ? I want to control XY effects with Nanopad.
Hey there,
thank you for your post.
You can map all simple buttons of the pad, also please open the midi learn feature and use the pad, are there different notes getting transferred to djay Pro?
Hi Lukas,
I have no problem about pad mapping. I have problem X-Y touchpad.
I cant control Djay FX X-Y surface with Korg X-Y touchpad
