Hi, I am helping out a friend to map Pioneer CDJ-350. But I have problem mapping the jogwheel platter for scratching and pitch bend. Also the display is not working, just showing pc connection with no track list or whatsoever. The rest of buttons are OK e.g. play, cue, tempo…Can someone help me on this matters, jogwheels scratch n pitch bend.
we added support of the CDJ-350, CDJ-400, CDJ-850, CDJ-900, CDJ-2000, XDJ-700
and improved our support of the CDJ-900NXS CDJ-2000NXS and XDJ-1000 with the new update of djay Pro 1.3.
Check it out.
Cheers,Lukas E.
