Mapping switch for MIDI configuration presets
This is a basic request based around having a modifier option!
given that we have presets for midi configurations of our controllers, if we had the ability to switch midi presets for a given controller we could effectively had a psuedo modifier state, where we simply change the controller preset, and remap accordingly…
be a bit of a pain in the arse to remap things… but im sure it would be useful
thoughts?
Thanks for the suggestion @7nz. I’ll share this with our devs.
its a straight forward suggestion but would solve the issue of modifiers…as you can switch configurations without issue… so long as you have sorted your mappings!
hope to see it, in the next update LOL
i wont hold my breath though
i could do this using keyboard maestro, as a work around…
but it would be more useful to the masses, if they understand the benefits of switching mappings, of the same controller…
additionally there “may” be a need to see which mapping is in play… unless you reduce your config mappings to just 3 or have a coloured LED on your controller to signal which preset you are on
Yeah, this sounds like a decent potential work around for modifiers.
