Meine Suche funktioniert nicht!
Egal was ich bei “Mein Mac” eingebe,… es kommt immer “keine Ergebnisse”
Kann mir jemand helfen?
Danke
Danke
Hi Markus,
have you added a folder to your “My Mac” library?
Hi Markus,
apparently the search function is able to search for files in these added folders as well.
How much folders are you working with?
Thank you in advance,
cheers.
Hi Markus,
the search function in the “My Files” section works for external hard drives as well. Could you tell us what hard drive you are using? Also do you have the possibility to check another external hard drive?
Thank you in advance.
Yes, but in this folder i have other folders,… thats the point! The search doesn’ work with sub-folders!?
I have around 20 Folders with 20- 30 folders in it,… and in this folders there could also be other folders,… And The search only works in the first folder,… maybe The external HDD is the problem???
