The microphone volume returns to zero every time it’s closed and turned off.
Is there any way the volume settings can be retained to save you always having to adjust the level settings?
As I host an online radio show this can become particularly annoying since the microphone is used quite often.
I could not see any other way to turn the mic on and off except for the on/off switch.
Any further info would be much appreciated
