MIDI command to change Visualizer (Video Mixing)
is there any option to change/select the visual loops in the video mixing section via midi? As I’m mostly mixing techno without any videos. I like to use the visual effects from the video loops. But I don’t find any option to assign new “visual loop” to a channel without diving into sub menu window, which is a bit too complicated during “audio” mixing. Otherwise the visuals stay the same during the whole set.
Hi @Christian_N, by “visual loop” do you mean the Visualizer selection?
@Slak_Jaw, yes, that’s what I mean. The selection of the visual pictures in your screenshot. Maybe a toggle or rotary would be nice.
Thanks for confirming @Christian_N. Currently there are no MIDI commands for this, but I’ve passed this onto the dev team for consideration. Thanks!
