You’re welcome @joccili. No there is not.
is vinyl break an effect that can be mapped? I see backspin, forward spin, censor, etc…vinyl break is a good one i use a lot
found it, nvm. its calledb brake effect
Excellent! Glad you found it @joccili
Thanks for figuring this out! This helped me map all of my go-to Crossfader FXs except for Drum Swap.
What note number aligns with Drum Swap? I tested them all with no luck. Thanks!
Hi there, should be 14
It worked, I appreciate ya!
Thanks again @Dysfunk_DJ!
brilliant! thank you ![]()
