MIDI issues with RANE System One
Using djay on rane system one using iPad Air and everything is up to date. I’ve midi mapped the bottom for pads of the hot cue to be instant effects 1-4 on both decks. Works great but after I turn the controller off, it reverts back to being hot cues. Is this just how it is or is there a way to keep the midi map forever?
Hi @Sonamabesh, when you edit a built-in mapping on iOS, djay keeps your edit as a separate configuration next to the integrated one. After you power the System One back on, djay seems to be selecting the built-in configuration again. Your Instant FX pads should still be there, so you can switch back to them:
  1. Go to Dashboard > Settings > MIDI Devices and tap RANE SYSTEM ONE.
  2. Tap your edited configuration so it’s the active one.
To make your version easier to spot (and to keep the original intact), duplicate it and give it your own name: Edit > select the configuration > Duplicate, then Rename.
Could you let me know your djay version, iPadOS version, Engine OS version and System One firmware version? Also, does it switch back to hot cues every time you power-cycle the System One, or only after djay has been closed? That’ll help me work out whether this needs to go to the team. Thanks!
Thank you. Didn’t realize I could have multiple maps. So each time I power it up, I have to go and select the correct one?
You’re welcome @Sonamabesh. Once you pick your edited configuration, djay should stick with it. If it keeps going back to the built-in one after a power-up, I’d like to look into that.
For now, re-selecting it in Dashboard > Settings > MIDI Devices > RANE SYSTEM ONE is the quickest fix. Do it before you start playing so the pads don’t catch you out mid-set.
To help me narrow it down, could you share:
  • Your djay version, iPadOS version and Engine OS version
  • Whether it resets every time you power-cycle the System One, or only when djay has also been closed
  • A short screen recording of you powering on, opening MIDI Devices, and showing which configuration is selected
