gavin
August 22, 2026, 6:19pm
1
Device model (e.g. 2020 iPad Air 4th Gen) :
Version of operating system (e.g. macOS 14.4.1) :
Version of djay (e.g. 5.1.2) :
Hardware/controllers used (e.g. Reloop Mixon 8 Pro) :
Hardware firmware version (e.g. 1.0.1) :
Please consider sharing a short video or screenshots to help clarify your question/suggestion/feedback
Im using the hercules impulse 500 on windows 11.
Every time I try to remap the pads for beat jump in cant find the option in the action menu
Hi @gavin , the MIDI commands you are looking for are called Skip not Beat Jump. They are all found after the Neural Mix section.
gavin
August 22, 2026, 10:10pm
5
I can’t even find those menus. Im trying to use SHIFT/SLICER. Then the pads. This is the closest I can get to what your photo.
gavin
August 22, 2026, 11:27pm
6
Thank you. Ive found it. Such a long process.
You’re welcome @gavin . Happy to help!
gavin
August 23, 2026, 1:32am
8
Can I transfer the settings to deck two or do I need to go over the process again?
You need to repeat the mapping process for each deck
gavin
August 23, 2026, 4:06am
10
Will do. Sounds like a suggestion for the programmers though my friend. Also when will video displays be available on the windows version of djaypro as it is on the mac?
Sounds good. We don’t have any news regarding video mode on Windows.
